KC_CHOW
Sep 19, 2020Follower
NIGHTHAWK RAX40: How to set schedule blocking
I am using Nighthawk RAX40 (Firmware Version V1.0.3.80_1.0.1), and I would like to set the schedule to block the wifi connection. After logging in, I have followed the instructions according to t...
Christian_R
Sep 25, 2020NETGEAR Employee Retired
Hi KC_CHOW,
Were you able to setup your schedule blocking? You may need to factory reset and run through the setup assistant again or power cycle the router.
Christian
