Columbus43204
Nov 05, 2020Follower
Nighthawk rax40 wifi not working
Our wifi network stopped working yesterday afternoon. We have isolated the problem to the router as the issue. I am using the rax40 with an arris surfboard modem. I connected an old laptop to the mode...
antinode
Nov 05, 2020Guru
> Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Firmware version?
> [...] an arris surfboard modem [...]
Model number?
> - no devices in the house can connect via wifi (range of Apple,
> Samsung, and google products)
What about a computer with a wired (Ethernet) connection?
> - I tried a hard reset by using a pushpin and holding it in for 20
> seconds it did not work
Which kind of "did not work"? Did the reset operation not happen, or
did the reset not solve the original problem?
"not work" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> Wondering if I can I put the firmware update on a jump drive and use
> the USB port on the nighthawk to install it [...]
You can't.
> [...] or if I am overlooking something
How about the obvious?
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot".
