jacobw77
Mar 02, 2021Follower
Nighthawk RAX40 Wifi stops transmitting
I have a RAX40 that works great, but it seems like after approx 12 hours the WiFi signal just stops transmitting. After I reboot the router it works great again, and it's a constant struggle. I'v...
Mar 02, 2021Guru - Experienced User
Did you setup a schedule?
Sometimes a simple factory reset and reinstall removes a setting that could be causing it. have you tried that?
