Nawar
Oct 19, 2019Follower
NIghthawk RAX40 WPS issues and firmware update from the app.
HI peeps . i haven't been able to find anything related to this issue on here so i'm hoping someone can help . first of all, updating the firmware from the app doesn't work, it says it is up ...
LsiC
Nov 17, 2019Aspirant
Brother printers often have very buggy wifi, you should definitely download their tool and update its firmware.
DeanOutlaw
Feb 17, 2020Aspirant
I'm having the same issue with my Epson ET-2550 multi-function printer.
I can see the printer when I am logged into the RAX40 wifi routers console and I can see the RAX40 on my broadband routers console.
But the Epson software on my computer that is connected to the broadband router can't detect the SSID of the RAX40 and thus can't connect to the printer
- SilvertonMYFeb 17, 2020Guide
Out of curiosity, are you using Windows as your operating system on your computer? If so, check to see if Windows set up your WiFi network as 'Public' or 'Private'.
Just a thought.
- DeanOutlawFeb 17, 2020Aspirant
Yeah it is windows
it was set to public and I had no luck there
I changed it to private still no luck
I tried turning off the firewall for both public and private and no luck.
When I had the wifi turned on on my braodband router the epson software was able to see my SSID but I ended up having issues with the wifi signal around the house so I got the RAX40
There might be another thing to look at.
When I set up my RAX35, I had to keep the 2.4Ghz WiFi side of my router enabled because my printer wasn't compatible with 5Ghz.
Just wondering if yours is the same. Did you set up the 2.4Ghz WiFi network on your new router, or is it disabled? I wonder what would happen if you connected your computer to the 2.4Ghz side of the router just while you set up your printer.
Also, don't forget to turn back on your firewalls that you turned off, once you get it all working.
Post back if successful (or not).
