Senna79
Jul 19, 2021Aspirant
Nighthawk rax40
Please help, All we did was go into and change the password and now have limited access on our internet since last friday, I have called over 8 times and the worst service I have ever experienced wit...
Jul 19, 2021Guru - Experienced User
1. you have the RAX40?
2. what firmware is on it?
3. what modem/gateway is it connected to?
- Senna79Jul 19, 2021Aspirant
Yes I have he RAX40 connected to a Netgear modem
I do not know about a firmware.
All I did was attempt to change a password and we have been down since last friday??
- plemansJul 19, 2021Guru - Experienced User
Try a simple factory reset and reinstall?
push and hold reset for 7-15 seconds while the router is powered on.
then reinstall it
- RangerXJul 19, 2021Apprentice
You state that all you did was attempt to change a password and now have limited access.
This is could be an Operating System networking issue.
1. What spcific password did you change. For example: Router Admin password, Wifi password, etc.)?
2. What operating system(s) / devices are you using that are now with limited access since the password change?
Netgear Modem cm1000v2
