kprice61
Oct 15, 2022Aspirant
Nighthawk RAX42 DNS not same for 2.4 and 5ghz
I cant figure out for the life of me why my 2.4 wireless connection is handing out googles DNS 4.4.4.4 and 8.8.8.8 instead of the routers DNS. My adapters are set to automatic (DHCP) theres no manua...
- Oct 17, 2022It is double NAT. Changing it didn’t fix dns though. There’s no VPNs installed. In the end I just discovered my ISP finally implemented parental management features through an app recently so I ditched the nighthawk since that’s the only thing I used it for and it cost money for the parental controls. Thank you all for your help
Oct 15, 2022Guru - Experienced User
What modem/gateway is the router connected to?
Your ip address is 10.0.0.1 which isn't the default. It switches to that if it detects its in a double nat.
So it could be that you're in a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
- kprice61Oct 17, 2022AspirantIt is double NAT. Changing it didn’t fix dns though. There’s no VPNs installed. In the end I just discovered my ISP finally implemented parental management features through an app recently so I ditched the nighthawk since that’s the only thing I used it for and it cost money for the parental controls. Thank you all for your help
