JMONTE_II
Jun 08, 2022Follower
NightHawk RAX43 Not Allowing Google.com or Any Google Services
Hi all, I have this really odd issue going on with my nighthawk RAX43 router. This just started yesturday afternoon. I am connected to the internet and all other websites work and I can stream Netfli...
microchip8
Jun 08, 2022Master
Did you change DNS servers? 8.8.8.8 or 1.1.1.1 are good ones
PS: you should never update firmware over WiFi or crappy apps, too many things can go wrong; use a wired connection. Also disable Automatic Firmware Updates
