JeebsBro
Sep 21, 2022Aspirant
NightHawk RAX43 Port forwarding Issue
Hi all, I can't seem to port forward my router. I will refer to the port forward server as a Minecraft one to be easy. 1. I use a third party program "PFPortChecker" Which I've used many times befor...
JeebsBro
Sep 24, 2022Aspirant
Ive added inbound and outbound UDP and TCP 25565 ports is that what you meant by listening?
JeebsBro
Ive got a static IP
Ive got inbound and outbound UDP and TCP rules for 25565
Ive got port forwarding internal IP address made to my PC's IPV4
Ive got LAN setting address reservation set to my PC's IPV4 so it's the same.
I'm thinking maybe my provider is blocking my connections. I'll have to call them when theyre open.
- microchip8Sep 24, 2022MasterNo
Listening = the server needs to be active (running) on the port you forwarded during an online port check. Otherwise it'll report it as closed- JeebsBroSep 26, 2022Aspirant
I've tried this aswell by starting my Minecraft server and looking for my port opening. I port forwarded my friends PC and router the EXACT same way ensuring every step is the same. We both have different outcomes as his Port forward worked and mine did not. I contacted my internet company and they do not have any Port block or limit e.t.c.
- michaelkenwardSep 26, 2022Guru - Experienced User
Did you try this:
Search - NETGEAR Communities – minecraft server
Maybe someone has been there before.
