Kevintuf
Nov 09, 2022Aspirant
Nighthawk rax43 wireless router wont connecting to laptop
I have a nighthawk rax43 wireless router, a netgear cm1100 router and a netgear ac1200 Range extender
Been working fine for a year.
this morning my network does not show up on my MacBook Pro.
restarted, etc. No luck
any thoughts?
That sounds possible, maybe even probable, but Netgear helped me set it up initially
as I have little to no experience with this equipment. Sadly my 90 day tech support has expired and I have no clue how to achieve what you propose…
Maybe I should check the yellow pages for a tech… Lol.
- microchip8MasterIs your auto-update of firmware turned on? There was yesterday or a few days ago an update that caused issues for some (like router got reset to its default settings)
If this is the issue, you'd have to set it up again and this time turn auto-update off- KevintufAspirant
- microchip8Master
Go to http://routerlogin.net or http://192.168.1.1, and in Advanced -> Administration -> Router Update, you can disable auto-update
For further assistance, go to NG's site, find the manual and read
