hxroberts
Mar 20, 2023Aspirant
Nighthawk RAX45 - can not change SSID back to previous
In doing a firmware update, a factory reset was somehow done, changing my SSID and PW back to the original which matches the stickers on the device. I then went and tried to change the SSID and PW b...
- May 11, 2023
My apologies for the delayed response/resolution but I've been away and recently returned to resolve this. As it turns out, I had an N300 WiFi range extender in the garage for the home security cameras and this was not allowing me to change back to my network name. I removed this first and then was able to make the changes desired, then reconnected the extender and all is now good. Thanks for all of your help.
Mar 20, 2023Guru - Experienced User
It's recommended to change the SSID name to a custom name other than what comes as default on the sticker.
- hxrobertsMar 20, 2023Aspirant
It was changed to a unique SSID and PW when it was setup in late 2020. I've been doing firmware updates and this is the first time it somehow did a factory reset. I want to change it back to what I had setup as my SSID.
- FURRYe38Mar 20, 2023Guru - Experienced User
Did you do a FR from the reset button in back or from the Backup menu in the web UI using the erase button there?
Thank you for responding. Neither - I had checked for updates in the App and there was one firmware update which I elected to install. When it was completed, it appeared to do a factory reset without my requesting it because the SSID was set back to the original on the sticker. So now I want to get mine back so that I don't have to go reconnect/setup my Ring, security cameras, smart devices, etc.
- michaelkenwardMar 20, 2023Guru - Experienced User
How do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
How do I change the WiFi password or security level on my NETGEAR router? | Answer | NETGEAR Support
I've followed those instructions. After I change the SSID and Network key (from the reset factory default) back to what I have had setup and been using for the past few years, I hit Apply and get the message "SSID is a duplicate, please change to another one" and no change is made. It is still at the factory name and key.
