hxroberts
Mar 20, 2023Aspirant
Nighthawk RAX45 - can not change SSID back to previous
In doing a firmware update, a factory reset was somehow done, changing my SSID and PW back to the original which matches the stickers on the device. I then went and tried to change the SSID and PW b...
- May 11, 2023
My apologies for the delayed response/resolution but I've been away and recently returned to resolve this. As it turns out, I had an N300 WiFi range extender in the garage for the home security cameras and this was not allowing me to change back to my network name. I removed this first and then was able to make the changes desired, then reconnected the extender and all is now good. Thanks for all of your help.
Mar 20, 2023Guru - Experienced User
It's recommended to change the SSID name to a custom name other than what comes as default on the sticker.
hxroberts
It was changed to a unique SSID and PW when it was setup in late 2020. I've been doing firmware updates and this is the first time it somehow did a factory reset. I want to change it back to what I had setup as my SSID.
- FURRYe38Mar 20, 2023Guru - Experienced User
Did you do a FR from the reset button in back or from the Backup menu in the web UI using the erase button there?
- hxrobertsMar 20, 2023Aspirant
Thank you for responding. Neither - I had checked for updates in the App and there was one firmware update which I elected to install. When it was completed, it appeared to do a factory reset without my requesting it because the SSID was set back to the original on the sticker. So now I want to get mine back so that I don't have to go reconnect/setup my Ring, security cameras, smart devices, etc.
You'll need to use a web browser and log in to the routers web page to make changes.
- michaelkenwardMar 20, 2023Guru - Experienced User
How do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
How do I change the WiFi password or security level on my NETGEAR router? | Answer | NETGEAR Support
I've followed those instructions. After I change the SSID and Network key (from the reset factory default) back to what I have had setup and been using for the past few years, I hit Apply and get the message "SSID is a duplicate, please change to another one" and no change is made. It is still at the factory name and key.
How was FW updated on the router? Via Nighthawk app or did you manually load FW using a web browser on the routers web page?
Did you FR using the back button or ERASE button on the WEB UI?
Can you try a different browser or PC and see if this SSID name will change?
When you did a FR, walk thru the setup wizard and when it gets to the part about setting up the SSID name, is this where your getting an error?
