hxroberts's avatar
hxroberts
Nighthawk RAX45 - can not change SSID back to previous
In doing a firmware update, a factory reset was somehow done, changing my SSID and PW back to the original which matches the stickers on the device.  I then went and tried to change the SSID and PW b...
  • hxroberts's avatar
    hxroberts
    May 11, 2023
    My apologies for the delayed response/resolution but I've been away and recently returned to resolve this.  As it turns out, I had an N300 WiFi range extender in the garage for the home security cameras and this was not allowing me to change back to my network name.  I removed this first and then was able to make the changes desired, then reconnected the extender and all is now good.  Thanks for all of your help.
