hxroberts
Mar 20, 2023Aspirant
Nighthawk RAX45 - can not change SSID back to previous
In doing a firmware update, a factory reset was somehow done, changing my SSID and PW back to the original which matches the stickers on the device. I then went and tried to change the SSID and PW b...
- May 11, 2023
My apologies for the delayed response/resolution but I've been away and recently returned to resolve this. As it turns out, I had an N300 WiFi range extender in the garage for the home security cameras and this was not allowing me to change back to my network name. I removed this first and then was able to make the changes desired, then reconnected the extender and all is now good. Thanks for all of your help.
Mar 20, 2023Guru - Experienced User
Try that then try a FR and walk thru the setup wizard using a web browser and PC, input the new custom SSID name during the setup wizard process...see if it will apply here.
Last resort would be to manually re-load FW, might even try prior working FW first using a wired PC and web browser. Setup, then manually re-apply the latest version of FW.
Seems like something is in a bad state here.
hxroberts
May 11, 2023Aspirant
- FURRYe38May 11, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
