uwdj75
May 21, 2022Follower
Nighthawk RAX45 - Where is the Transmit Power Control after latest firmware update?
My Nighthawk RAX45 router is updated to firmware version V1.0.11.112_2.0.77. I cannot find the Transmit Power Control anywhere. Did Netgear remove that option from the firmware? (It used to be on th...
CD_router_888
May 25, 2022Guide
Transmit Power Control was removed from v1.0.11.112.
tallpeak
Jul 16, 2022Aspirant
Then the UI should show the current setting, 25% (where I left it) or 100% (if forced to that new value by the firmware update), grayed-out to indicate that I cannot change the transmit power anymore. Removing the functionality while hiding the fact that it was removed was confusing! (Is it at 25% now, where I left it? I'm only getting 2 out of 5 bars, 30 feet away...and it works okay I guess, but I lose packets sometimes; it might work better at 50%, or do I need to move the router closer?)
- FURRYe38Jul 17, 2022Guru - Experienced User
More then likely the power is at 100% after you did the FW update. To ensure this, do a factory reset and setup from scratch. The UI should read 100% or grayed out or no longer appearing in the UI.
