uwdj75
May 21, 2022Follower
Nighthawk RAX45 - Where is the Transmit Power Control after latest firmware update?
My Nighthawk RAX45 router is updated to firmware version V1.0.11.112_2.0.77. I cannot find the Transmit Power Control anywhere. Did Netgear remove that option from the firmware? (It used to be on th...
tallpeak
Jul 16, 2022Aspirant
Then the UI should show the current setting, 25% (where I left it) or 100% (if forced to that new value by the firmware update), grayed-out to indicate that I cannot change the transmit power anymore. Removing the functionality while hiding the fact that it was removed was confusing! (Is it at 25% now, where I left it? I'm only getting 2 out of 5 bars, 30 feet away...and it works okay I guess, but I lose packets sometimes; it might work better at 50%, or do I need to move the router closer?)
Jul 17, 2022Guru - Experienced User
More then likely the power is at 100% after you did the FW update. To ensure this, do a factory reset and setup from scratch. The UI should read 100% or grayed out or no longer appearing in the UI.
