nexusguy59
Feb 28, 2023Tutor
Nighthawk RAX45 / Physical network not working.
Hello Everyone, Another problem arose after plugging in the new nighthawk. My physical network 192.168.xxx.xxx which goes to port one on my JGS524Ev2 and is trunked is now not working....
- Mar 08, 2023
Hey Guys,
I figured out the problem, I had it set for tagged instead of untagged. Once I set it to untagged the Physical network came up and started communicating.
Thank you for responding. I do appreciate the help,
Michael
Feb 28, 2023Guru - Experienced User
Have you tried a different device in that port?
Or tried switching the switch to a different port?
nexusguy59
Feb 28, 2023Tutor
I haven't as of yet. However, the link light on both ends shows green. I would think that means it's good. I have had the switch set up for a few years with the same config and never had a problem. So I am not sure what is going on with it.
Thanks,
Michael
- plemansFeb 28, 2023Guru - Experienced User
Thats why its worth trying a different device.
to see if its actually a problem with the router or a setting on the switch.
You said the RAX is new so maybe its something you had setup prior on the switch.
- nexusguy59Feb 28, 2023Tutor
Yup it could be, I am getting ready to replace the switch and try it. My old ASUS RT AC3200 was working fine and I don't remember anything special being done other than trunking port one on the switch.
I appreciate you very much by the way Thanks for your input.
Thanks,
Michael
- nexusguy59Mar 08, 2023Tutor
Hey Guys,
Michael
