nexusguy59
Feb 28, 2023Tutor
Nighthawk RAX45 / Physical network not working.
Hello Everyone, Another problem arose after plugging in the new nighthawk. My physical network 192.168.xxx.xxx which goes to port one on my JGS524Ev2 and is trunked is now not working....
- Mar 08, 2023
Hey Guys,
I figured out the problem, I had it set for tagged instead of untagged. Once I set it to untagged the Physical network came up and started communicating.
Thank you for responding. I do appreciate the help,
Michael
nexusguy59
Feb 28, 2023Tutor
Yup it could be, I am getting ready to replace the switch and try it. My old ASUS RT AC3200 was working fine and I don't remember anything special being done other than trunking port one on the switch.
I appreciate you very much by the way Thanks for your input.
Thanks,
Michael
nexusguy59
Mar 08, 2023Tutor
Hey Guys,
Michael
