silentbystander
Jan 14, 2021Aspirant
Nighthawk RAX45 AX4300 Shows corrupted device name suffixes in Advanced> Attached Devices>
Nighthawk RAX45 AX4300 Shows corrupted device name suffixes in Advanced> Attached Devices> Firmware Version V1.0.2.66_2.0.42 The downlink is connected to a GS308PP 8 port Gigabit Et...
Christian_R
Jan 20, 2021NETGEAR Employee Retired
Hi silentbystander,
Have you had a moment to perform a factory reset? If so, curious to hear the results.
Christian
silentbystander
Jan 24, 2021Aspirant
I backed up the router, and performed a factory reset. I waited, for the unit to reboot, then went through prompts to set up the router again.
I saw a seemingly intact list of connected devices, with no random repeated name repeating down the list.
I restored from the config file I had backed up a few minutes earlier, and waited a few minutes till it applied again. The garbled names appeared again after applying the saved config. I'm going to reset to factory again, and manually configure and see if the issue presents from a manual setup on a fresh factory restore.
