dbarnesmsn
Aug 15, 2021Aspirant
Nighthawk RAX45 AX4300 VPN Passthrough NOT Working
Just installed a new Nighthawk WiFi-6 Model RAX45 AX4300 router.
The VPN passthrough appears to be blocked but I can't find where to enable typical VPN passthrough settings (IPSec Passthrough, PPTP Passthrough, and L2TP Passthrough) . However, I don't see where in the configuration settings to change these settings. I checked under Setup | WAN setup and found no L2TP passthrough settings. Firmware Version is V1.0.2.82_2.0.50.
Where are the VPN passthrough setting?
Thanks,
Dale Barnes.
- DarrenMSr. NETGEAR Moderator
Did you ever get the VPN pass-through to work?
- dbarnesmsnAspirant
No I never did get the VPN Passthrough to work. NH guides did not reflect settings on the router.
