DonKOtay
Oct 22, 2021Aspirant
Nighthawk RAX45 (Costco) only sees internet when NordVPN is running (Spectrum ISP)
My situation seems odd... I use Spectrum and a Motorola modem (not a Spectrum router, just the modem). I have been running my network using Google Wifi and I wanted to connect something which ...
- Oct 22, 2021
Well, I got this thing working by hardcoding the Google DNS servers in my Nighthawk router.
I used 8.8.8.8 and 8.8.8.4.4 instead of getting it from the ISP.
Still not sure what the issue was and maybe I'll probe more later. It seems to me that getting it
from the ISP should work for the Nighthawk just as it did for the Google Wifi. Maybe Google Wifi
uses the same DNS servers. Anyway, just going to go with what I have because I won't have to
put NordVPN on ALL my connected devices...
I also checked the connection with my Samsung and now it works as well, so I'm good for now...
I will trash that Armor software anyway, so maybe I'll switch it back later to test.
But for now, the DNS server change from automatic to selecting the servers works, so I'll go with it.
Thanks to all who gave pointers...
DonKOtay
Thanks for the suggestion, I may see if that helps.
FWIW, I did try the Nighthawk router all by itself and it has the same problem.
I didn't mention this step in my initial description, because that was already a bit long.
I've also gone through some of the regular debugging such as powering off/on and waiting and
similar things.
At this point, I am suspecting that the Nighthawk might have something fishy in its DNS setup,
so I will get back in later this morning and go through that with a fine-tooth comb. I just noticed
something odd in the DNS address last night which I may pursue on the router. It's the only
other clue I have. It wasn't the usual 192.168.1.1 but had another address. Worth a look, even
though it looks fine now. I remember seeing something odd...
Oct 22, 2021Guru - Experienced User
Is Armor enabled or has it been enabled at any point?
