Jesenko
May 31, 2022Follower
Nighthawk RAX45 drops wired connections
I have a RAX45 it started dropping wired connections regularly fix is unplugging from devices and plugging back in. It does not effect wireless connections at all. Set up is Fiberwire modem --> RAX...
michaelkenward
Jun 01, 2022Guru - Experienced User
What's the firmware on the RAX45? A number is more useful than "the latest".
Have you tried a factory reset ion the router?
Is this "Fiberwire modem" a simple box rather than a modem/router?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
