meow_j
Oct 28, 2021Initiate
Nighthawk RAX45 Firmware update failure with "gui language file is invalid"
Firmware Update Assistant New firmware is found. Do you want to update the firmware? (Yes) (No) Current GUI Language Version: 1.0.2.82_2.1.46.1 New GUI Language Version: 1.0.4.100_2.1.46.1 Curren...
- Oct 28, 2021
Have you tried manually installing the next update?
then seeing if it'll auto update?
Oct 28, 2021Guru - Experienced User
meow_j
Thank you very much. Manual update worked fine.
- plemansOct 28, 2021Guru - Experienced User
Glad it worked for you!
- FURRYe38Oct 28, 2021Guru - Experienced User
Enjoy. 📡
