meow_j
Oct 28, 2021Initiate
Nighthawk RAX45 Firmware update failure with "gui language file is invalid"
Firmware Update Assistant New firmware is found. Do you want to update the firmware? (Yes) (No) Current GUI Language Version: 1.0.2.82_2.1.46.1 New GUI Language Version: 1.0.4.100_2.1.46.1 Curren...
- Oct 28, 2021
Have you tried manually installing the next update?
then seeing if it'll auto update?
BikeinDv
Nov 19, 2021Initiate
While manually downloading the file and installing the firmware from your directory works, I am disturbed that Netgear allows this issue to be distributed without some clear communication on what they plan to do to fix the problem. Their QA test must be very poor.
DavyCrocket
Nov 28, 2021Aspirant
I agree this is very unprofessional.
