AGNG2020
Sep 10, 2024Tutor
Nighthawk RAX45 not retaining SSID after reboot
Hi everyone - I've had this router for 4 yrs, and need to change SSID. The router takes the SSID and password change fine and works as long as you don't reboot or cycle power. Once you reboot or cycl...
- Sep 14, 2024
The factory reset "witchcraft" did the trick!... was actually able to use a CFG backup that I created right before it, and magic!.. all worked again and SSID stays after reboots. Thank you much michaelkenward and mlm44 !
