AGNG2020
Sep 10, 2024Tutor
Nighthawk RAX45 not retaining SSID after reboot
 Hi everyone - I've had this router for 4 yrs, and need to change SSID. The router takes the SSID and password change fine and works as long as you don't reboot or cycle power. Once you reboot or cycl...
- Sep 14, 2024The factory reset "witchcraft" did the trick!... was actually able to use a CFG backup that I created right before it, and magic!.. all worked again and SSID stays after reboots. Thank you much michaelkenward and mlm44 !
michaelkenward
Sep 12, 2024Guru - Experienced User
Have you tried the suggestion from mlm44?
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front. It is also the first thing that Netgear support will recommend.
Just another user with time on their hands.
AGNG2020
Sep 14, 2024Tutor
