Rex_W's avatar
Rex_W
Nighthawk RAX45 Router Hacked?
My SSID was changed to Bernie_RAX45 from the name I gave it. I did a master reset and it went back to Netgear##, but it no longer allows me to log in with the app or access the internet.
  • plemans's avatar
    When you reset, did you have to fully reinstall it?
    • Rex_W's avatar
      Rex_W
      Yes, I tried to do a complete me install. Part of the problem was our ISP was down. So we only had a local network but no internet. It's working now. I still don't know how the SSID got changed?
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        It looks to be part of the firmware that is causing the name to be changed to that not someone hacked your router and changed the name I have reported this to the engineers.
        DarrenM
