gtdurham
Jul 09, 2022Follower
Nighthawk RAX45 Starts Broadcasting SSID when I use the Nighthawk mobile app
I have setup my Nighthawk router to not broadcast my SSID. If I use the Nighthawk mobile app either on my iPhone or android tablet, it reset the SSID on my 5GHz network to broadcast the SSID. Any su...
michaelkenward
Jul 10, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
