CJ-USA
Oct 27, 2022Aspirant
Nighthawk RAX45 Stopped Broadcasting Wifi
My Nighthawk RAX45 will intermittingly stop broadcasting wifi signals. All items directly connected to the router can access the internet but the wireless items will not see the router. After a few...
iyang
Nov 01, 2022NETGEAR Expert
Hi CJ-USA ,
Did you change wifi setting before you find stop broadcasting wifi signals ?
Could you check if broadcast wifi is enable or disable from gui ?
Thanks.
- CJ-USANov 02, 2022Aspirant
Hello iyang NETGEAR Expert,
Please see my reply below to your questions.
Question: Did you change wifi setting before you find stop broadcasting wifi signals ?
Answer: No, I did not change my wifi settings. I turned the router off (unplug) for a few hours and when I turned it back on later the problem started happening.
Question: Could you check if broadcast wifi is enable or disable from gui?
Answer: The broadcast wifi is enabled.
Any suggestion will be welcomed. Thanks
CJ-USA
