kkgregc's avatar
kkgregc
Nighthawk RAX45 stopped broadcasting
Hi, I have a Nighthawk RAX45 (from Costco) and just today, for no apparent reason, it is no longer broadcasting. I have done the reboot sequence where you unplug everything, then plug them back in o...
  • plemans's avatar
    May 27, 2022
    I've seen it happen after a firmware update. Its pretty rare but some updates need a reset to clear out old settings that can cause issues.
    But you've got it working now after reinstalling? If so, I'd make a backup in case it happens again.
