kkgregc
May 26, 2022Aspirant
Nighthawk RAX45 stopped broadcasting
Hi, I have a Nighthawk RAX45 (from Costco) and just today, for no apparent reason, it is no longer broadcasting. I have done the reboot sequence where you unplug everything, then plug them back in o...
- May 27, 2022
I've seen it happen after a firmware update. Its pretty rare but some updates need a reset to clear out old settings that can cause issues.
But you've got it working now after reinstalling? If so, I'd make a backup in case it happens again.
kkgregc
It appears my router did some sort of reset. My custom settings were all erased and it went back to the factory default. Any idea why it would do that on its own?
May 27, 2022Guru - Experienced User
- kkgregcMay 27, 2022Aspirant
Thank you
Yes it all seems to be working now
