wes78
Jan 30, 2022Initiate
nighthawk rax45 trouble connecting to google speakers and bond hub
Hello, I am having some trouble connecting my new nighthawk rax45 wifi router to my google speakers and my bond fan control hub. I have a motorola ac1900 modem with built in wifi. The 2.4g on the mot...
Jan 31, 2022Guru - Experienced User
A couple things.
Turning off wifi doesn't turn off the routing features on the motorola. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
also, make sure to be on the same 2.4ghz or 5ghz as the devices you're trying to setup. If the device only supports 2.4ghz, have the phone you're using for setup on 2.4ghz.
Some older devices have issues with wpa3 and AX. You can try making sure to use wpa2 security. You can also disable AX on the 2.4ghz.
either of these might help get them connected.
- wes78Jan 31, 2022InitiateOk thanks, I don't know much about all this stuff. I was hoping it was plug and play. I will try solution 1 when I get home from work. Hopefully I can find that feature on the modem. Thanks for your help.
