Eddie_Ramirez
Mar 19, 2021Follower
Nighthawk RAX45 wont connect to internet
I really need some help. I followed the app instrucstions, but I can't get past the "cable" connection error which is right before the "connected to internet phase". It's like the nighthawk doesn...
Christian_R
Mar 22, 2021NETGEAR Employee Retired
Hello Eddie,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
