maxman76
Oct 26, 2023Tutor
Nighthawk RAX48 STOPS WORKING when HD connected to USB
Whenever I plug my external SSD into this POS, the WiFi totally stops working. Can't connect to it at all! WTH, Netgear!? I paid good money for this thing, and it fails completely with a USB drive ...
- Oct 26, 2023
I figured it out. My SSD is 4TB. I found something that basically said the router can only handle up to 2TB partitions.
After adding a second partition (so that both are set to equal size - 2TB), it is working, and I can access my files on the drive via readyshare!
michaelkenward
Oct 30, 2023Guru - Experienced User
Most routers can handle larger USB drives. I have one at 8TB.
Netgear's KnowledgeBase piece in drives is inaccurate and incomplete.
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
What they do not like is partitioned drives. They can't see separate partitions.
On the other hand, it is hard to see how that would wreck the wifi.
maxman76
Oct 30, 2023Tutor
Yeah. now even after partitioning it, the router still just stops working completely if the drive is connected. It's a Samsung 4TB SSD, NTFS formatted. Maybe a problem with the router, or the drive takes too much power to run from the USB port (it uses a USB A to USB C cable)?
- michaelkenwardNov 01, 2023Guru - Experienced User
maxman76 wrote:
Maybe a problem with the router, or the drive takes too much power to run from the USB port (it uses a USB A to USB C cable)?Sounds like a logical assessment. My 4 TB WD Elements has its own power supply.
I have run smaller drives off the USB ports.
The RAX48 does have USB3, but it could be on the edge of the power supply.
- maxman76Nov 01, 2023TutorI wonder: would it be possible to use a powered USB hub, plug the drive into the hub for power, then the output of the hub connects to the USB port on the router?
maxman76 wrote:
I wonder: would it be possible to use a powered USB hub, plug the drive into the hub for power, then the output of the hub connects to the USB port on the router?Worth trying.
