Alex_A25
Oct 24, 2022Aspirant
Nighthawk rax48 will not send out internet connection
I have tried all known solutions besides a factory reset of my router and I still cannot get wifi. I have the Nighthawk RAX48 AX5200-6-Stream Wifi Router (bought 2 years ago). I have attempted all typ...
Oct 25, 2022Guru - Experienced User
Try the factory reset. Tends to be quick/easy.
Are you able to log into the router?
Try its ip address
Alex_A25
Oct 25, 2022Aspirant
Factory reset did not work. Continuously says internet not connected.
- plemansOct 26, 2022Guru - Experienced User
Can you access the modem using its ip address?
got a screensnip of its cable connections page and event logs?
- Alex_A25Oct 26, 2022AspirantI do not know how to do that. I do not have a computer with an Ethernet port if that involves trying to connect a device directly to the modem.
Side note - I tried using my old modem as well last night after realizing this wasn’t working and it still failed to find an internet connection.
