Weezmen
Nov 29, 2022Aspirant
Nighthawk RAX50 - Cannot download on Google Play Store
Hello All, Just installed a brand-new Nighthawk RAX50. Out of the box everything works pretty well except one thing : My Android smartphone (Samsung S20 FE 5G) cannot download any updates or new ...
- Dec 03, 2022
Hello,
Just getting back on this. I may have found the issue cause & solution.
I just remind my ISP is providing IPv6 and I figured the IPv6 settings were not configured....
I've gone in "Advanced -> Advanced Setup -> IPv6" and select "Auto Detect".
Once validated, the routeur has selected "Pass Through" and it looks like to have solve my issues !
I can now download & updated in Google Play Store.
I have looked into my smartphone IP settings & I can find DNS is both provided in IPv4 & IPv6. Maybe this was part of the problem.
Nov 29, 2022Guru - Experienced User
How is the Basic and Advanced Tab wireless settings configured?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Using WPA2 and AES?
- WeezmenNov 29, 2022Aspirant
Firmware is V1.0.11.112_2.0.77, I will post some more details.
Behavior is really strange with Play Store : sometimes it never start the download and some others time it stuck at 99%. In all cases the updates or new apps never installed through the router (but works fine on others wifi or cell network).
Appart this issue it looks like everything is working pretty fine : browsing, streaming (like Netflix), etc...
The issue is definilty with the router, not my ISP, as another wifi router device connected on the same internet box as no issue with Play Store.
- FURRYe38Nov 29, 2022Guru - Experienced User
Does this happen with other Android devices?
I have just tested with my old Android smartphone (UMI Super). It is based on an older version of Android but and I have exactly the same problem.
I have made a quick diagram to explain the issue. Will be happy to provide more details if necessary.
