Weezmen
Nov 29, 2022Aspirant
Nighthawk RAX50 - Cannot download on Google Play Store
Hello All, Just installed a brand-new Nighthawk RAX50. Out of the box everything works pretty well except one thing : My Android smartphone (Samsung S20 FE 5G) cannot download any updates or new ...
- Dec 03, 2022
Hello,
Just getting back on this. I may have found the issue cause & solution.
I just remind my ISP is providing IPv6 and I figured the IPv6 settings were not configured....
I've gone in "Advanced -> Advanced Setup -> IPv6" and select "Auto Detect".
Once validated, the routeur has selected "Pass Through" and it looks like to have solve my issues !
I can now download & updated in Google Play Store.
I have looked into my smartphone IP settings & I can find DNS is both provided in IPv4 & IPv6. Maybe this was part of the problem.
Weezmen
Firmware is V1.0.11.112_2.0.77, I will post some more details.
Behavior is really strange with Play Store : sometimes it never start the download and some others time it stuck at 99%. In all cases the updates or new apps never installed through the router (but works fine on others wifi or cell network).
Appart this issue it looks like everything is working pretty fine : browsing, streaming (like Netflix), etc...
The issue is definilty with the router, not my ISP, as another wifi router device connected on the same internet box as no issue with Play Store.
Nov 29, 2022Guru - Experienced User
Does this happen with other Android devices?
- WeezmenNov 29, 2022Aspirant
I have just tested with my old Android smartphone (UMI Super). It is based on an older version of Android but and I have exactly the same problem.
I have made a quick diagram to explain the issue. Will be happy to provide more details if necessary.
- FURRYe38Nov 29, 2022Guru - Experienced User
Seems that your ISP Modem (Freebox Revolution) has a router and wifi built in here? IF so, This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
Try option #2 first...- WeezmenNov 29, 2022Aspirant
Thank you for your quick reply. I will check my internet box config & let you know.
