NickyUK79
Feb 06, 2022Follower
Nighthawk RAX50 multiple issues
Bought this a few days ago and it's been a NIGHTMARE. Tried Router mode, AP mode.
Issues:
wifi - worked at the start. I got half a day then Boom. Nothing now, it's not broadcasting. a Blip here and there, zero lights on the router for the wifi.
Ethernet - Worked at first with the BT home hub , it registered in the network table and assigned an IP e.t.c. from the BT HUB.
*All these issues end up with a solid orange or red light on the router. Router stays off like that for a few mins , starts up again.....
POWER :Solid Orange => white
INTERNET: blank => Orange => White
Ethernet connections : blank => White flashing. I'm only using one cable.
if I'm lucky, the router might pick up the ethernet port and allow 10 second access to the web interface. I change a settings then *all lights go off except solid orange.
rinse and repeats....I've reset, factory reset. read lots of troubleshooting. on and off.
This is broken I'm sure, oh and a rollback never worked.
1 Reply
If you just bought it and the wifi light isn't even staying on, I'd stop fighting it and return/exchange it. maybe you got a bad unit.
