tmac16
Feb 18, 2021Aspirant
Nighthawk RAX50 Only Solid Power LED
I recently tried to update the firmware from the Nighthawk app on my moble phone over Wifi and now only the Power LED is lit white and solid. Tried the factory reset for 7-15 second with no luck. A...
tmac16
Hi plemans,
Thanks for the reply. I did try the windows TFTP but I get a "Connect request failed" message. Also this procedures states the same as the Tftpd64 where the link on the router is blinking or solid and amber. Mine is a solid white only, with nothing else. Not sure how much that matters.
Feb 18, 2021Guru - Experienced User
did you try the nmrpflash?
- tmac16Feb 18, 2021Aspirant
Going to try that now, but wanted to reply since you took the time to help and I wanted to you to know I am working the process. The nmrpflash looks a little more involved so that will take me some time to read and figure out.
Thanks!
- tmac16Feb 23, 2021Aspirant
Hi plemans,
Unfortunately nmrpflash did not work either. Once i get the Waiting for physical connection and turn the router on after a short time i get Error: Ethernet cable is unplugged. I did confirm i was using the correct eth using the nmrpflash -L command.
Tom
