tmac16
Feb 18, 2021Aspirant
Nighthawk RAX50 Only Solid Power LED
I recently tried to update the firmware from the Nighthawk app on my moble phone over Wifi and now only the Power LED is lit white and solid. Tried the factory reset for 7-15 second with no luck. A...
thehypnootoad
Feb 23, 2021Luminary
Netgear support is terrible I'm currently trying to rma a rax120 try this method https://youtu.be/XeoS0xVINOE this way helps alot better
tmac16
Feb 23, 2021Aspirant
Hi thehypnootoad,
This video looks the same as my first step plemans had me try and that did not work. The bulk of the fixes i saw using the TFTP mention flashing lights, which mine does not have. I only have 1 solid white light for power.
tmac16
