OmarValenzuela
Nov 28, 2023Aspirant
Nighthawk RAX50: Problem connecting a smart device
I have a smart device for my garage door opener. It works with wifi, so I tried to register this smart device to the wifi (I use the nighthawk RAX50 router) and is not connecting, it always times ou...
Nov 28, 2023Guru - Experienced User
What band is the phone connected to when you try to set it up?
What modem is the router connected to?
- OmarValenzuelaNov 30, 2023Aspirant
The phone is also connected to the 2.4GHz band, my internet provider is Wide Open West (WOW)
- plemansNov 30, 2023Guru - Experienced User
But what modem/gateway is the router connected to from WOW
Its a Netgear cm1000v2
