OmarValenzuela
Nov 28, 2023Aspirant
Nighthawk RAX50: Problem connecting a smart device
I have a smart device for my garage door opener. It works with wifi, so I tried to register this smart device to the wifi (I use the nighthawk RAX50 router) and is not connecting, it always times ou...
Nov 28, 2023Guru - Experienced User
What band is the phone connected to when you try to set it up?
What modem is the router connected to?
OmarValenzuela
Nov 30, 2023Aspirant
The phone is also connected to the 2.4GHz band, my internet provider is Wide Open West (WOW)
- plemansNov 30, 2023Guru - Experienced User
But what modem/gateway is the router connected to from WOW
- OmarValenzuelaNov 30, 2023Aspirant
Its a Netgear cm1000v2
- michaelkenwardDec 01, 2023Guru - Experienced User
Standard cable modem. No router in there to complicate things.
What is this smart device? Have you asked the maker for help?
Too many makers of IoT stuff don't seem to understand how the Internet works.
