OmarValenzuela
Nov 28, 2023Aspirant
Nighthawk RAX50: Problem connecting a smart device
I have a smart device for my garage door opener. It works with wifi, so I tried to register this smart device to the wifi (I use the nighthawk RAX50 router) and is not connecting, it always times ou...
Dec 01, 2023Guru - Experienced User
Is IPv6 enabled?
Any VPN's in use?
if you're on apple devices, make sure icloud relay and private mac/ip address features are disabled
