wuzhemin
Oct 17, 2021Aspirant
Nighthawk RAX50 ReadyShare cannot recognize my Kioxia 1TB SSD in Orico enclosure
Hi All, I have a Nighthawk RAX Wifi-6 Router. And I'd like to connect one external SSD drive (Kioxia 1TB NVMe SSD + Orico enclosure) to its USB port so that I expect to share files in this SSD th...
Oct 18, 2021Guru - Experienced User
Have you tired a different USB drive connected to the router. Maybe a mechanical drive to test and see if something else works?
wuzhemin
Oct 18, 2021Aspirant
Yes, I have tested both a SanDisk 32G usb stick and a WD external HDD. Both worked with no issue. Only my Kioxia + Orico enclosure doesn’t work. Now I’m suspecting this enclosure has some compatibility issue with the router.
- FURRYe38Oct 19, 2021Guru - Experienced User
Sounds like it...
