kqcef
Jul 12, 2020Tutor
Nighthawk RAX50 Wifi Capped at 200mbps
Hi there, I’m trying to troubleshoot why my wifi speeds are so much slower than the signal that the router is receiving from the modem, especially when it’s below the max for the RAX50. I have a...
Jul 12, 2020Guru - Experienced User
Are you testing wireless?
Many things impact wireless speeds from device used, antenna configuration of your device, distance, interference, drivers, etc.
What wired speeds do you get when directly connected to the router?
Firmware on the router?
kqcef
Jul 12, 2020Tutor
Yep! Testing wirelessly. I don’t have any devices that have an ethernet port to test with unfortunately.
- plemansJul 12, 2020Guru - Experienced User
Its tough to tell you if theres an issue or if its related to the device you're testing with based off your info.
- kqcefJul 15, 2020Tutor
Sorry about that. Just got an ethernet adapter, speeds clocking in around 380-410 on a Macbook Pro. Any ideas what might be throttling the WiFi throughput?
