kqcef
Jul 12, 2020Tutor
Nighthawk RAX50 Wifi Capped at 200mbps
Hi there, I’m trying to troubleshoot why my wifi speeds are so much slower than the signal that the router is receiving from the modem, especially when it’s below the max for the RAX50. I have a...
Jul 12, 2020Guru - Experienced User
Are you testing wireless?
Many things impact wireless speeds from device used, antenna configuration of your device, distance, interference, drivers, etc.
What wired speeds do you get when directly connected to the router?
Firmware on the router?
kqcef
Jul 15, 2020Tutor
Firmware version is v1.0.2.30_2.0.37
- plemansJul 15, 2020Guru - Experienced User
it might actually be the wireless devices themself.
a couple things.
1. 2.4ghz is much slower than 5ghz.
2. 5ghz speeds drop off quickly with distance/obstructions
3. a 1x1 antenna device isn't going to be as fast as a 2x2 antenna device
What link speed are your devices showing? your actual throughput speed is going to be roughly 55-65% of what your link speed is.
- kqcefJul 15, 2020Tutor
plemans Yes, sorry, should specify that I'm testing WiFi speeds on the 5ghz network directly next to the router to reduce any sort of interference or distance variables.
From my MacbookPro, the Tx Rate (which I believe is the Link Speed) is currently 780mbps
What site are you using for speed testing? speedtest.com doesn't always pick the fastest server. I'd try several of them.
since the RAx has been updated, have you tried any factory reset and reinstalls? That RAX devices were released before the AX spec was even finalized and have responded well to factory resets after changing firmware.
Another though is what modem are you using?
