kqcef
Jul 12, 2020Tutor
Nighthawk RAX50 Wifi Capped at 200mbps
Hi there, I’m trying to troubleshoot why my wifi speeds are so much slower than the signal that the router is receiving from the modem, especially when it’s below the max for the RAX50. I have a...
kqcef
Jul 15, 2020Tutor
I used a few:
Google: 182.0
Ookla: 223.17
Speakeasy: 217.5
Fast.com: 180
I've tried factory resets, updating to the latest .40 hot fix firmware, no change in speeds
I'm using an Arris SB6183
Thanks so much for the help!
Jul 15, 2020Guru - Experienced User
tried enabling ipv6?
Did you ever get full speed with it?
How old is it?
- kqcefJul 15, 2020Tutor
Haven't tried IPv6, but both modem and router were brand new out of the box the day I first posted :). before getting on the phone with customer support, I was only getting around 80mbps with the default settings...
- kqcefJul 16, 2020Tutor
Tested with IPv6, negligible difference if not a bit slower (~180mbps as opposed to low 200s)
- plemansJul 16, 2020Guru - Experienced User
I would open a support case with netgear.
click mynetgear at the top and register an account and then the device
from there you can open a support case
Hmm. If ethernet speeds are also coming in at around 250mbps, would that give you any other ideas? I might have been looking at the wrong value before. Now I'm testing on a ethernet -> usb-c adapter and it's coming in at 250
- kqcefJul 19, 2020Tutor
Unfortunately I've already done so and doing whatever changing of settings they suggested only got me to the point we're at now (started at 130mbps before support call, ended up with the speeds I started this thread with). Looks like I'm going to return and purchase a different router, especially because I just received a replacement for this unit and it actually performed worse with the same settings, both connected to ethernet and connected to WiFi
