kqcef
Jul 12, 2020Tutor
Nighthawk RAX50 Wifi Capped at 200mbps
Hi there, I’m trying to troubleshoot why my wifi speeds are so much slower than the signal that the router is receiving from the modem, especially when it’s below the max for the RAX50. I have a...
Jul 16, 2020Guru - Experienced User
I would open a support case with netgear.
click mynetgear at the top and register an account and then the device
from there you can open a support case
kqcef
Jul 19, 2020Tutor
Unfortunately I've already done so and doing whatever changing of settings they suggested only got me to the point we're at now (started at 130mbps before support call, ended up with the speeds I started this thread with). Looks like I'm going to return and purchase a different router, especially because I just received a replacement for this unit and it actually performed worse with the same settings, both connected to ethernet and connected to WiFi
