technova
Jun 17, 2025Aspirant
Nighthawk RAX54 Not Broadcasting Wifi
Router's 2.4 and 5 GHz lights went out today suddenly. The power, internet, and wifi lights are solid white but the router isn't broadcasting any signal. I tried using the Nighthawk app to see if I'm...
technova
Jun 18, 2025Aspirant
I double-checked the wifi switch by pressing it on and off and that doesn't seem to be the issue since the wifi LED is on. I've tried using an ethernet cable to connect the router to an external device and the external device isn't getting an ethernet signal either.
Jun 18, 2025Guru - Experienced User
Try a factory reset and setup from scratch using a PC and web browser?
