sd10wrangler
Mar 29, 2024Guide
NightHawk RAX70 - Laptops cannot connect to internet, 26 other devices can...
Nighthawk Tri-Band AX8 RAX70. Router Firmware Version V1.0.15.146 Windows 11 Pro Home Studio As the title suggests I am having a big problem with my two laptops which both connect to the router ...
Mar 29, 2024Guru - Experienced User
If other devices are working then I would look at these two laptops.
Ensure there DNS are configured and cleared out. IPCONFIG /flushdns is a good command to try in a command line.
Contact the Mfr about support and information regarding there product.
https://kb.netgear.com/23/How-can-I-troubleshoot-DNS-resolution-problems
https://kb.netgear.com/30510/How-do-I-set-static-Domain-Name-System-servers-on-my-NETGEAR-router
- sd10wranglerMar 29, 2024Guide
Internet Modem Is Netgear CM 500 Docsis 3.0
