sd10wrangler
Mar 29, 2024Guide
NightHawk RAX70 - Laptops cannot connect to internet, 26 other devices can...
Nighthawk Tri-Band AX8 RAX70. Router Firmware Version V1.0.15.146 Windows 11 Pro Home Studio As the title suggests I am having a big problem with my two laptops which both connect to the router ...
michaelkenward
Mar 29, 2024Guru - Experienced User
sd10wrangler wrote:
As the title suggests I am having a big problem with my two laptops which both connect to the router ok, but have no internet connection.
Similar problem over here, with the same questions:
Re: Nighthawk RAX70 will not connect laptop to int... - NETGEAR Communities
I had one hint that it could be a DNS problem but I don't know how to change that.
Hint from where?
- sd10wranglerMar 29, 2024Guide
I have tried flushing the DNS but that didn't work . Also tried using Google DNS 8.8.8.8. & 8.8.4.4. Also didn't work.
I will call HP.
I spoke to Tech Support and they discovered that my Asus repeater was causing the problem!
All is working well now, both laptops connected!
Thanks !
- michaelkenwardMar 30, 2024Guru - Experienced User
Good to hear something positive about support.
Any clues as to what the problem was? It might help someone in the future.
